running in takes ages!
Discussion in 'Home Cinema Speakers' started by dts_boy, Mar 8, 2002.
  1. dts_boy
    dts_boy
    Nov 26, 2001
    2,669
    Manchester suburbs...
    +215
    i have the k series also and can't think of anything that even comes close at the price! as for running in, it does take a fair while...100hrs if i remember correctly. out of the box they will not sound too great but its worth the wait. on a 5 channel dsp mode will be fine at low levels - just as long as yer bird is happy:D
  2. Taz
    Taz
    and frustrating at the same time! B&W recommend 30 days for my S3's
    So you get a new set of speakers and have to sit on your hands so as not to touch the volume.. but its all worth it in the end the last thing you'd want to do is damage one.
    Taz.:cool:
  3. General Skanky
    General Skanky
    Jul 28, 2000
    4,252
    71
    Colchester
    +44
    Taz, being protective of your new babies?
    Get them blasting! As long as the amp etc are warmed up you'll be ok.
    A beer or three will help with the acoustic perceptions!:D
    If you don't, my perception of you will drop to p***y status.
    Only playing.
  4. Taz
    Taz
    Ok I admit it, I couldnt take more than two days of looking at 'em and not hearing em so...I kicked their Kevlar buts!:D
    Do as I say, not as I do springs to mind!;)
    Taz.:cool:
  5. General Skanky
    General Skanky
    Jul 28, 2000
    4,252
    71
    Colchester
    +44
    I did wonder how long it would take a ,red rag to a bull' after you came online to respond!:)
    At lest u r in butch status again.
  6. M.Joshi
    M.Joshi
    Oct 10, 2000
    249
    Harrow.
    +9
    I read somewhere that you can speed up the process by selecting a radio station (With some 'noise') on your tuner and leaving it on while you are not listening to the speakers - at a low volume level.
  7. Darth Vader
    Darth Vader
    Feb 13, 2002
    102
    16
    Middlesex
    RE: Radio station noise
    What a novel idea!.
    But using the pink noise generator on your amp would be a better bet as this uses most of the audio spectrum range, making all drivers in your speakers work as hard as each other. So all the cones in your speakers will break in at the same time.
    Just set the pink noise generator to auto and it will switch to all your speakers in turn. Remember to keep the volume to a reasonable level as long exposure to pink noise would drive you bonkers!.
  8. uncle eric
    uncle eric
    For the fastest most even burn in of your speakers and all other new componenets in the chain, a great product is Ultra CD 3000, available from www.testdisc.com
    Eric
