Running in settings for 42PHD6
Discussion in 'Plasma TVs' started by Northmoorblue, Jul 10, 2004.
  1. Northmoorblue
    Northmoorblue
    May 18, 2004
    36
    Anyone got a list of desired setting to be used while running in my new panny 42PHD6.
    I have searched but only come up with people saying the settings should be low for the first 200 hours, but without any real figures / options.
    Grateful for any help from panny owners, or others if general figures for settings apply to all plasmas? :lease:
    Northmoorblue
  2. Northmoorblue
    Northmoorblue
    May 18, 2004
    36
    Can anyone out there in AV land take the time to give me a few hints at least which would be helpful, or am I being a bit boring with my request? :boring:
    Northmoorblue
  3. jmack
    jmack
    knock the contrast and brightness down a bit
    around -10 for both i had mine set at.
    but whatever is best for you, factory settings are usally very hot mine was set to +20 :eek: :eek:
  4. Northmoorblue
    Northmoorblue
    May 18, 2004
    36
    jmack
    Thanks for the tip.
    Northmoorblue
  5. kacang
    kacang
    have a look on avsforums for the subject 'steaming rat' that will help you, even without the aid of a special calibration disc to set your plasma to good and still detailed and accurate settings, most liekly you will find that picture and brightness will go down below the zero level. and the lower they are the better for your plasma..
    erick
