Running hours on Pio 434/504?
Discussion in 'Plasma TVs Forum' started by dvdsubtitles, Sep 27, 2004.
  1. dvdsubtitles
    dvdsubtitles
    Anyone know how I can check how much running time my 504 has had? I'm sure I saw something about this on the forums before, but can't seem to find it.
    Cheers,
    Mat.
  2. sparkz
    sparkz
    Nov 21, 2002
    219
    19
    Southampton
    This link shows you how to get into the service menu. I assume this is the place where you get the hours from like on my PDP433MXE. The same menu on the 433 is a lot simpler: menu then switch on.
    Mark
  3. dvdsubtitles
    dvdsubtitles
    Mark,
    Many thanks - this did the trick!
    Cheers,
    Mat.
