Running dual displays in XP question
Discussion in 'Desktop & Laptop Computers Forum' started by RobsterD, Jul 16, 2003.
  1. RobsterD
    RobsterD
    Dec 11, 2000
    891
    Southampton
    +12
    Ive just bought a cheap and cheerful 15" TFT display which I've connected to the DVI input via the analogue convertor of a 9500 Pro,the main analogue o/p is going to a Panny plasma.
    I'm trying to configure the TFT to have all the shortcuts etc and when I start powerDVD etc I want it to start the application on the plasma.
    So far I've only been able to acheive this if I clone the displays and then I lose the native res for the plasma.
    I downloaded ATI Hydravision but I cant seem to get that working either.
    Is this acheivable ? or am I missing something really obvious,seem to be going round in circles any help would be really appreciated.
    rob
  2. nfordenfield
    nfordenfield
    Apr 9, 2001
    625
    19
    Kent
    You'll need to check the expand my desktop settings on monitor 2, then move the start bar and desktop items to the TFT (assuming that is Monitor 2)
  3. GaryRees
    GaryRees
    Hi Rob
    Go to settings - advanced - display and make your TFT the primary display. You then need to click on the overlay tab and after clearing the overlay warning, select Theater Mode.
    This should now give you a full screen picture on your plasma and a normal desktop on your TFT.
