Running Co-Ax behind plaster board
Discussion in 'Cables & Switches' started by TheSeer, Jan 24, 2004.
  1. TheSeer
    TheSeer
    Dec 23, 2001
    142
    Hampshire
    +3
    Hello,
    Moved into a new-build house about a year ago. Unfortunately, the builders have run in some cheap coaxial cable to the various different rooms from the loft.
    Is there relatively easy way to replace these cable runs with good quality stuff, without having to tear up plaster board walls etc.
  2. smeghead
    smeghead
    Jan 21, 2001
    95
    KENT
    +3
    If the walls have been drylined with plasterboard you might have a problem as the plasterboard is stuck to the wall.
    you will find it should have a solid row of adhesive along the ceiling line,down the edge of corners and along the floor for the skirting to fix to and around the sockets.
    If you give the wall a tap around the sockets etc with a hammer(a light tap don't go mad) if there is nothing behind it should sound hollow.
    you never know you might be lucky and find a gap.
    then you might be able to use the old cable as a draw cord.
    good luck fishing for cables.
    Dean
  3. STOWITBELOW
    STOWITBELOW
    Nov 17, 2002
    1,578
    48
    Lancashire
    +49
    Tug at one end of the old coax. if it moves at the other end (Two people or long arms required) use it as a draw cord as Smeghead says. Take care connecting new to old though. It would be iritating to pull it halfway through & it gets stuck & becomes detatched. If no movement there is no easy way )-:
  4. patmyhead
    patmyhead
    Feb 11, 2002
    588
    I o M
    Have you thought about a video sender?
    bonus is that you get control of your equipment from other rooms
    + some send a stero signal as well
    P@T
  5. installer09
    installer09
    Aug 26, 2002
    415
    16
    SWINDON ,WILTS
    I do this kind of thing for a living , I always drop new cables down the cavity , as long as they are not insulated .
  6. TheSeer
    TheSeer
    Dec 23, 2001
    142
    Hampshire
    +3
    Hello installer09
    Thanks for replying (and everyone else). Seeing as you do this for a living, any idea roughly how much it might cost to get this done by a pro?
  7. installer09
    installer09
    Aug 26, 2002
    415
    16
    SWINDON ,WILTS
    Depends on the construction really , probably about £80 per run , try STOWITBELOW's advice first , most new build houses , esspecially tv points to upstairs can be done this way.
