I've been trying to figure out the best way to get a reliable and fast network connection from downstairs (router location) to upstairs (future HTPC). I've considered Homeplugs but discounted because of expense and the fact we have old wiring so I doubt i'd get decent speeds. MoCa might be an option but I would still need to lay some cable for that and the boxes are expensive. Wireless is out as I want to stream HD content.
So it's Cat5e/6. I can't route it through the house so my only option is to route it outside of the house.
Are there any special considerations I should take note of when doing this? I've read you can get UV sheilded cable for outdoor use but I've also read this isn't likely to be necessary for home installations. I live in the north of england so it does get pretty cold but it will be out of direct rain (apart from when it comes down sideways!). I'm trying to keep the costs down so I don't want to be buying specialist cable unless necessary.
Can the cable be run alongside satellite and regular coax cables? Any intereference issues there?
I was initially going to go with Cat 6 because it is higher graded for not much more money but I read that you have to be careful when bending it whereas Cat 5e isn't quite so finicky, is that right? Reason I ask is that after running the cable along the wall I will need to bend it at a fairly sharp angle in order to get it in through the wall. Does Cat 5e have any issues with bending?
Thanks!
Thanks!
