Running cables
Discussion in 'Cables & Switches' started by Pip_UK, May 3, 2002.
  1. Pip_UK
    Pip_UK
    This may sound like common sense but I didn't think of it until a mate suggested it to me
    I bought a new video lead for my projector (RGB syncblaster 10m cable for the Sony 11HT). I had decided to conceal it in the wall and ceiling so it looked better. I was going to chisel a channel up the walls and across the ceiling.
    My mate suggested drilling small holes in the ceiling every 3 foot and thread a piece of string on an extended wire coat hanger ... yes it was difficult and it took an hour ... but once done I was able to pull the cable across the ceiling with very little plastering (you cannot even see the holes if your a reasonabley competent with Polyfilla.
    If you attempt to do this make sure your ceiling rafters are running the right way and there are no cross beams in your path
    Pip:p
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    I would suggest putting a smallish hole (fist sized) at the source and end of your cable run and using some sort of flexi tube to be pushed through from one end. Tape you cable to the end and pull it through.
    We use this technique at work loads, it's so easy.
    Still not as easy as taking own the whole ceiling and wiring everything first mind... :)
  3. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    I would just take up the floor boards above......then you have no filling to do, only need a quick half hour from the carpet layer!
    ad
  4. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    +59
    If only life were that easy always Buns!
  5. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    It is! its easier actually......its the roof space above me......so no carpet to worry about!
    :D
    ad
