Running a Scart lead through a Brick Wall???
Discussion in 'Cables & Switches' started by bezza, May 11, 2005.
  1. bezza
    bezza
    Hey all,
    I've just ordered a plasma which is going to be mounted above my fireplace. In order to hide the cables i need to drill a hole through some brick work which allows me to run the cables round the corner out of sight.
    However how do you fit a Scart lead through a reasonably small hole? Can you buy scart cables which can be dismantled and fed through a hole and then reassembled?
    Any help or tips would be greatly appreciated.
    Bezza
  2. FunkyMonkey
    FunkyMonkey
    Dec 11, 2002
    1,491
    48
    +83
    Easiest thing is to remove a brick, then put it back in after feeding cables. Shouldn't be difficult to lay it back in! :eek:
  3. bezza
    bezza
    Unfortunately the bricks are part of a chimney stack and the direction the hole for the cables need to go prevents bricks being removed.
    The whole being drilled will be approx. 15-20cm in length.
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,237
    The Borders
    +2,940
    bezza
    QED SQARTS can be 'dismantled' - you end up with the termination block attached to the cable which you can pass through a 'smallish' hole and then reassemble the SCART hood on the other side of the wall.
    Best regards
    Joe
  5. bezza
    bezza
    Excellent, I'll give that a go. Many thanks.
