Captain Tex
Hi -- I need to run about 50 feet of wiring in the walls of my home to connect a source (RCA) to the auxiliary input (1/8" (3.5mm)) on a speaker system. What’s the simplest way of doing this?
My sense is that I cannot simply run a 50' RCA audio cable (rated for use in walls) because of quality loss.
Instead, I thought it would make sense to run Cat6 and use a balun on each end:
Would this work reasonably well?
Thanks!
Thanks!
