runco VX-1000c DLP Projector
Discussion in 'Projectors, Screens & Video Processors' started by beamer133, Nov 1, 2004.
  1. beamer133
    beamer133
    Sep 28, 2004
    346
    +9
    Seen one of these for sale. Do they operate by themselves or do they need another module for input. I know Runco are good but some of their projectors are 2 box systems. Is this? Having trouble deciding on a projector. Originally wanted the Screenplay 5700 then out came the Panny AE 700 which on paper seems better. Then throw in some cheap CRT's on ebay and my mind is in a turmoil. Which way should I go. Thanks for any advice.
  2. Oakleyspatz
    Oakleyspatz
    Oct 9, 2004
    3,576
    Woking
    +231
    I would say you have a choice of 4-5 projectors !!
    The upcoming Sony VPL-HS50 ( Hi Def, 6000:1 contrast ratio, £1899)
    See the full specs at: http://www.avland.co.uk/sony/vplhs50/vpl-hs50.htm
    The Panasonic AE700 as you mentioned
    The Optoma H57 ( 3500:1 contrast ratio, DLP, Widescreen 1024 x 576 £1899)
    See full specs at: http://www.hifibitz.co.uk/product.asp?id=3603
    The Sanyo Z3
    The Infocus ScreenPlay 5700 ( DLP, 1024x576 PAL Prog, 1400:1 contrast )
    If it were my money, I'd wait for the Optoma H57!!
