Run in and black bars on DVD?
Discussion in 'Plasma TVs Forum' started by peterakastorm, Sep 17, 2005.
  1. peterakastorm
    peterakastorm
    Just a quick little question... In the run in period, the black bars at the top and bottom is ok, right? I mean black can't burn in, right?
  2. bishman
    bishman
    Mar 29, 2001
    4,903
    83
    hertford
    +172
    you can get uneven wear though, when the bulk of the screen gets used and part of it isn't used. Bars in moderation will surely be fine though.
  3. peterakastorm
    peterakastorm
    Uneven wear... I know the meaning of that, but the consequence? Will it be the same as burn in, just the "other way around"?
  4. tscotsman
    tscotsman
    Dec 29, 2004
    848
    +16
    exactly, best to expand the picture to fill the screen during the run in period
  5. peterakastorm
    peterakastorm
    Ok, damn... I've been watching alot of DVD movies because I thought it would be for the best! But I don't think I've been doing any damage...
  6. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    screen burn isnt actually any kind of burn, its all uneven wear, so having black bars is pretty bad until you've run it in, but dont worry too much, an hour or two equalled out with an hour or two of full screen viewing will be fine :)
  7. peterakastorm
    peterakastorm
    Ok, thanks... I also think I'm a llittle too paranoid on that matter... I'll just watch alot of full screen tv from now on :D
  8. scrapbook
    scrapbook
    Jan 12, 2002
    7,411
    +550
    I find it amazing you even have to avoid black bars on these TV's for x number of hours!!
    There are almost unavoidable in these days...even channels like kiss seem to have permanent black bars top and bottom with logos and title of artist etc etc
  9. Lionheart
    Lionheart
    I think the idea of the run in is to age all the phosphors at an equal rate and so anything static on the screen regardless of what it is doesnt allow this. As the phosphor are brand new and the first 200hrs is obviously when they are "bedding in" I dont think its to unreasonable to take this run in precaution. Of course at the end of the day each of us can do what he likes with our screen but personally, and as they are not exactly cheap to buy, I wouldnt take the risk....ps..of course after the 200hrs it really isnt a problem.....i just treat my plasma, now that it is ran in, as anyother tv and watch with black bars and logos without worry (42pv500)....it seems though the first 200hrs are important and static stuff should be avoided on screen for to long...there is no need to be paranoid about it though..just common sence is all the approach you need :)...pps...if you cant see any retention Peter then you are ok...just finish a run in from now on
  10. stanleyntl
    stanleyntl
    Dec 6, 2003
    809
    28
    Worthing, Sussex
    +44
    Reading another threads entry concerning screen run in : by Jvwaard, who cites a Panasonic white paper :
    ftp://ftp.panasonic.com/pub/Panason...s/Plasma-WP.pdf
    This magic 200 hrs is by no means an all clear for safe Plasma use, you have to clock up another 800hrs to reach a point whereby a screen wipe will remove any retention incurred by normal use.
    Up til then I would think it prudent to still maximise screen use - zooming DVD picture to remove black bars etc.
  11. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    for me, 200hrs is acceptable, but 800hrs is too long if that is how lon the "run in" takes. maybe they should start running them in at the factory with some accelarated program.
  12. phcahill
    phcahill
    Apr 11, 2005
    45
    Any chance of reposting the link to the pdf file.
    I've had no luck find it on the ftp server.
    Paul
  13. bishman
    bishman
    Mar 29, 2001
    4,903
    83
    hertford
    +172
    I've not been too worried about the black bars, just keeping them to moderation. If I'm watching a movie for a couple of hours and it's got bars at the top, I don't see that as a problem. Similarly if I'm watching friends or something and it's in 4:3, I'm not going to be losing any sleep.
    One thing I have done though is to make sure that the good lady has anything on in a full screen mode and doesn't watch the same channel for too long while I'm at work. I think I have made her the one who is paranoid about burn but that can't be a bad thing. I would be really mad if I came home to a QVC logo burnt into the screen :)
  14. stanleyntl
    stanleyntl
    Dec 6, 2003
    809
    28
    Worthing, Sussex
    +44
  15. phcahill
    phcahill
    Apr 11, 2005
    45
  16. peterakastorm
    peterakastorm
    I'm getting a little paranoid though... But my brightness is all down to about 10%, or lower, so when it's dark, almost all the screen is black... so I think it's ok even... of course the bars that are black all the time will be more black...!
  17. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    What screen, Peter? Some are more prone than others, but paranoia is pretty much not needed these days. You hear the odd horror story, but most likely someone's not taken the beast off dynamic mode, and gone to sleep whilst their zonked out kids sit there hypnotized for 8 hours. Maybe they should get out more.
  18. peterakastorm
    peterakastorm
    It's a Panasonic PWD8... So it should be ok, right? And as I said, both my contrast and brightness settings are at about 10% if not less... So almost as far down as it can go... Still watchable though! Especially on DVD! Cable is a little so so, but I can cope for the first 200 hours ;) 50 gone so far...
  19. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    I usually leave PWDs set to -3 or so, brightness and contrast, initially. No need for any less, and it's usually not far off where they end up either. No client of mine has ever suffered screen burn BTW.
  20. peterakastorm
    peterakastorm
    Ok? -3 only? That's far up, I must say... But right now I'm watching a 2.5 hour long movie, and I'm not able to get the black bars off... but it should be ok?
  21. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    i did with my pwd7 from the outset and had no problems....enjoy your film! :)
  22. Lionheart
    Lionheart
    no need to go to low Pete...just what u find good but below 50%...its just a guideline so dont worry ...if u cant get the black bars off try using the picture zoom settings of the dvd player...I had the same thing via HDMI when watching dvds...the TV wont work on zoom but the dvd player will
