Run a 3ohm sony sub from an onkyo 805?
Discussion in 'Home Cinema Speakers' started by sparkoss, Jan 15, 2008.
  1. sparkoss
    sparkoss
    Dec 21, 2007
    89
    11
    Kent
    +11
    I have an old sony DavS800 subwoofer which i am hoping to use until my special order Jamo c80sub arrives.(2-4 weeks)
    The sony sub is 100w and rated 3ohm.
    I know the 805 drives down to 4ohm with over 180w per channel.
    Would i be able to drive the 3ohm sub adequatly with the SR805?
    i have no idea if its any sort of risk and any help will be appreciated :)
    Thanks.
  2. stevelup
    stevelup
    Aug 13, 2002
    6,780
    Swindon
    +1,284
    It won't work at all - the subwoofer output on the Onkyo is unpowered.
    You will need to hook up a spare amplifier to to the subwoofer output on the Onkyo, then connect your subwoofer to that.
    Steve
  3. sparkoss
    sparkoss
    Dec 21, 2007
    89
    11
    Kent
    +11
    yeah, that was my first thought, oh well i think its still possible to do with the sony all in one just powering the sub. a bit annoying but better than no sub!
    thanks for the answer!
    Oh and by the way i did know the sub output is unpowered, i meant power it through the + and - which the sub uses! (the sub is unpowered)
