Question Ruipro hybrid or other
Gazaman
Joined
Jun 22, 2007
Messages
2,222
Reaction score
242
Points
493
Location
Chesterfield
Hi folks, I’m about to pull the trigger on a 10m ruipro hybrid to feed through the ceiling of my new home. I don’t currently have the need for 4K or have anything even capable but as it’s going in the wall it’s best to futureproof right!?!
Now I’ve looked through threads on here and the ruipro seems favourite for longer runs but they are also quite pricey. For a 10m run is this actually required or is it over kill.
Another question that I haven’t been able to find the answer to is....if it’s a faulty cable would it just not work full stop?or could it potentially transfer 1080p and not 4K? I don’t want to test it with my kit now, feed it through the wall then discover in 6 months time that 4K fails.
Gaz
At 10m you are beyond where you can rely on a Standard copper cable for 4K UHD.
Each RuiPro Hybrid Fibre cable we ship is pre tested in a system running SKY Q and ATV 4K to ensure we know they work when we ship them.
Ensure you install the correct way around - the ends are marked.
As mushii suggests it is a good option to run within a conduit if you are worried about damaging any cable when works are going on.
A failed or damaged cable will simply stop working - no matter what signal format you are transferring so always have a Plan B.
Joe
Joe
It’s a new build property and I’ve asked for the cable to be run at the time of all electrics etc so I guess it’s how far they are prepared to go for me. I’ll ask them if it’s possible to put some conduit up the wall and into the ceiling then. They can only say no I suppose.
Is there any discount code for avf members?
Gaz
Yes it was called the advice :) Consultation normally runs at £100 an hour. You will not be charged for the normal first 30 minutes. Enjoy
Yeah nice one, appreciate your reply.
I’ve seen other sponsors offer discounts so thought I may as well ask before placing my order and finding out after :thumbsup::thumbsup::thumbsup:
Never hurts to ask, although the sign in my local pub said otherwise....
PLEASE DO NOT ASK FOR CREDIT, AS A SMACK IN THE MOUTH OFTEN OFFENDS !!!
I can recommend the cable (I have the 10M) and Joe's service.
Not asking for credit bud. Just asking if there was a forum discount code as it’s very common for forums sponsors to offer a members discount. Yes or no wouldn’t have made a difference to my decision but thought I’d ask.
So maybe get yourself a ladder and get down off that horse of yours :smashin:
Joe
Thanks Joe for your helpful and informative answer. Cable ordered.
Thanks again
Gaz
@Gazaman it was said in jest, the reference was not aimed at you but an anecdotal quote that is often seen behind bars of local pubs. I am not sure why you think I was on a high horse. My advice here has always been given non-judgmentally and I try not to to belittle or embarass people no matter what the level of experience or the nature of the question, if you read any of my threads or responses.
Having had experience of actually just installing a 10m Ruipro in a conduit, in new build, I was going to try and provide you with some further helpful advice, but as you seem to have taken exception to my postings, i will bid you good luck with your install and leave it there.
Hello all
No harm in asking :)
mushii has some great advice and first hand experience with installing the RuiPro cables.
Too easy to get 'caught up' in online Forums - hopefully we can all continue to support each other.
Joe
@Gazaman is the run going to be a straight single run or will it need a bend in it? Depending on which I can recommend the diameter of conduit that you can use.
Cheers @Joe Fernand, I guess sometimes posts get read not the way they were intended. Certainly no harm intended here.
Apologies if I misinterpreted your replies mate.
It was a genuine question and I wasn’t expecting any special personal discounts or anything, just wondered if there was any forum discounts to try and make my confession to the Mrs a bit easier o_O:D.
I installed mine through 6 x 90 degree (wide radius) bends. Very convoluted but managed it. I used a 38mm flexible cable duct from a company called Hilltop who specialise in flexible conduit. It took 3 hours in total and a lot of patience. I had to go through the centre of an 8m long RSJ. I have to say the product does exactly what it is supposed to.
BTW I didn’t tell SWMBO it would only have resulted in more shoes.
Mine will basically enter at low level where my kit is then up the wall to a 90 degree bend where it will the travel the length of the room to the projector. I’m hoping the sparky can do it for us before we move in but I’m still waiting for an answer back from them.
If it were my install I’d run it in conduit if I could. If not I’d at least run it in the wall in 25mm od conduit and then just run it unclipped to the PJ and out of a brush plate. That way if you have to replace it, it will mean cutting a single access hole in the ceiling by the wall to feed a new one in. Easily patched in 10 mins. Just make sure that the spark doesn’t clip it. Alternatively run it in the ceiling in 25mm conduit but don’t connect the vertical and horizontal. You will still need to cut a hole but it will be mostly protected. The cable is very thin and very flexible.
BTW dimensions of the plug can be found here
RuiPro Hybrid Fibre Optic HDMI cable - The Media Factory
PS Joe there is a typo in the Description - Rupio
@mushii ive never installed using conduit before but I think that’s the way I’m gonna go. Does the conduit just lay in the ceiling and drop in the wall or is it clipped or held in any way? Also if I do as you say above and have either conduit in just the wall or both the wall and ceiling, do you think the 90 degree bend would be too much to drag it out hence your having to cut an access hole comment if needed?
Cheers for your help
Gaz
The conduit will be clipped to the wall (behind the plaster board) and will be clipped to a joist. The bend radii are huge 60 - 70 cm min and you would need to use much larger diameter conduit. I had to chase my block work to get my 38mm duct in. The hole will be needed if you have to reinstall a new cable (unlikely in the short term but all electronics eventually fail) just to thread between the two conduits.
It should take your spark no more than 30 minutes to fix it for you.
Ok thanks mate. I’m just hoping they agree to do this for me pre plasterboarding as I’m guessing something like this would be an absolute nightmare after.
Make sure you run some draw string through as well so you can pull the cable back and pull the new one through if the cable fails.
If the two conduits are not joined a single draw-string / cable will not work, but two separate draw cables maybe useful.
Ah right, I just assumed it would be best attach a cord to the cable when removing it and then use this cord to pull through the new one!?
You can also do that, then just feed between the two conduits via the cut access hole.
@mushii did you say yours was a new build? Did their contractors do it for you or did they allow your own input pre-completion?
StormAudio ISR Fusion 20 AV Receiver - review coming soon #HomeCinema #Amplifier #VideoShort
Back
