Rugged portable DAB radio
Discussion in 'Music Streamers' started by Pandion, Aug 15, 2013.
  1. Pandion
    Pandion
    Aug 15, 2013
    Wondering if anyone can recommend a portable, rechargeable, waterproof, rugged DAB radio. I work outside in all weathers and am struggling to find something that suits. I have had a Roberts solar for two years which has been great but it doesn't like being dropped from a height, submerged in ponds or having trees felled onto it. There are some good looking building site type radios but most are mains powered and I am not usually anywhere near a plug.
    I have looked at the Oasis flow and nearly bought one but for the apparent dodgy battery situation. Also, I don't need the Internet radio, wizardry and fluff as I only listen to 5live.
    Any suggestions much appreciated.
    Thanks.
