rubbish sound from sky digital
Discussion in 'Sky Digital TV Forum' started by nigelcraft, Dec 17, 2001.
  1. nigelcraft
    nigelcraft
    Mar 18, 2001
    87
    uk
    i listen to my sky digital through a technics dolby digital/surround system,yet on a lot of broadcasts when people are talking it mainly comes from the centre speaker but i also can hear the talking from the left and right front speakers(which sounds a bit muffled and strange)my question is should talking sounds come from left and right speakers or should it just be coming from the centre ,or is that just what happens in 5.1 mode on a dolby digital film on dvd??,the music ad stuff comes out of the left and right speakers but also from the centre speaker too,im a bit confused and am unsure if i have it set up right,hope someone can help (and understand)
  2. Family Guy
    Family Guy
    You will get "centre channel bleed" from Dolby surround sources. The centre channel is not a discrete channel in a Dolby surround track as it is in a Dolby Digital 5.1 track. The centre channel is decoded by the processor in the same way as the Ex channel on Dolby Digital Surround Ex 'tracks. Dolby Surround 'tracks actually only consist of Left, Right and a mono rear effects channel.
    No system that I have heard is without at least some bleed from the centre channel on DS 'tracks.
    Hope this helps. On the other hand, you may be using a DSP mode on your amp that makes it sound actually worse than it is.
  3. saggu1
    saggu1
    I have a grundig sky digibox.
    I dont think I have a optical or co-axial output.
    How do I connect the digibox to my Yamaha DSP620 amp to get digital sound??..
    i have a L and R output from the digibox..
  4. Family Guy
    Family Guy
    You can't I'm afraid.
  5. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    Bad news I'm afraid, without an optical output you can't.
    The best you can get is a Dolby Prologic soundtrack via the phonos.
    SKY+ has the the optical output and the Sony digibox has the output but it can't be activated due to it's software.
    Beat by seconds Army Bloke:)
  6. Family Guy
    Family Guy
    You know the motto - "Be The Best"!!;)
  7. Doubledoom
    Doubledoom
    I always find it is better to come last.....
  8. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    Nigelcraft,
    When you say that you can hear dialogue coming from the left and right speakers is that from your normal seating position as channel bleed shouldn't be apparent under normal watching conditions.
  9. nigelcraft
    nigelcraft
    Mar 18, 2001
    87
    uk
    no you cant really hear it from my seating point its just if i happen to be near the speaker for some reason or another i can hear it
  10. Family Guy
    Family Guy
    That's normal for Pro Logic. See my previous reply
