Rubbish black on a pw7
Discussion in 'Plasma TVs Forum' started by philthyanimal, Mar 14, 2005.
  1. philthyanimal
    philthyanimal
    Well after hearing so much about the PW7 i decided to buy one.
    What can i say, the picture is terrible. Unless i crank up the brightness and contrast to well over 13, i get what can only be described as dancing green pixels on dark colours. This is on DVD and Sky. Its so bad i've not been able to watch any of my starwars movies. :thumbsdow
    feeling very disappointed, I know i should have demoed but no where near me had one.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    Whoa some thing is very wrong there!!!!!!!!!!
  3. superpixel
    superpixel
    Panasonic's may be a lot of things, but being rubbish at blacks and dark scenes isn't one of them...
    maybe there's a fix to be found here http://www.avforums.com/forums/showthread.php?t=149333
    you're in the right place to get it diagnosed/solved anyway - I'm sure someone can help...
  4. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    how are you connecting to the pw7?
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    what is ambient light level?
  6. philthyanimal
    philthyanimal
    right, i'm connecting sky+ with a js rgb to vga converter. the scart out of the sky to js box is a qed rgb only flat performance cable. The vga is a red van damme one. The DVD palyer is 757ai, and i'm using one of mark grants component cables to the dual slot board on the palsma. The room is very dark.
    I've read the link you posted, thanks for that :thumbsup: I have mine set on cinema, if i have the brightness and contrast on -3 then its awfull.
  7. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    you couldn't connect it much better!! (in fact it is exactly same cables as I use...only the dvd player is different) have the advanced settings been tweaked?
  8. philthyanimal
    philthyanimal
    no, i'm not 100% sure what the advanced settings change so i haven't put them on yet.
  9. philthyanimal
    philthyanimal
  10. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    there is a gamma setting, which i set to s-curve. S-curve handles mid range tones like shadows and stuff and makes a difference...certainly worth trying..there are other gamma settings too. Have you been into service menu and made sure it's a new screen?
  11. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    try colour temp "warm" and Gamma 2.2 and 2.5
  12. philthyanimal
    philthyanimal
    I'll try that
    How do i check the service menu? would i be looking for the hours?
  13. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    also set to cinema (you need to turn advanced settings on to get into Gamma controls...also check for picture controls on DVD player picture see if it has birghtnees adjustment etc..
  14. phillfyspoon
    phillfyspoon
    Oct 21, 2003
    2,149
    Hampshire
    +76
    I have a pw6 and a denon 2900 and I find the pic is better going through the JS converter then using component.
  15. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    to check the service menu.....hold down volume - on the panel and press the status button on remote three times (button under the standby button)...go to SD options you will see two numbers labelled something like wt and pt...anyway left number is number of times turned on and the other is hours viewing.
  16. Peabo
    Peabo
    How close are you to the plasma? You're always going to see 'dancing green pixels' if you're too close to a plasma, that's just the way they are. You should be at least 6 feet if not 9 feet way!
  17. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Sounds like a small chance it's actually faulty! Anything can and does happen. It's certainly true you see green pixels in panasonic blacks, but not loads of them unless maybe as Horny says, the source brightness is set too high, and it's not being sent real black at all, and is struggling to display 'not quite black'. Usually you'd have to be as Peabo says, less than 6ft away to see the green dots. They must be present in large swathes to notice from any further. I've seen this before, it was cured by turning the contrast down to something resembling the right level.
  18. philthyanimal
    philthyanimal
    i'm gonna wait for my new DVD player before i do the calibration. Should be here in a couple of weeks. Then i'll use the dve disk.
    Thanks for all your tips. Gonna try them all out with sky tonight.
