rubber studs?
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by sc1977, Sep 13, 2005.
  1. sc1977
    sc1977
    Jul 16, 2002
    600
    kent
    +8
    ive just bought a soundstyle rack for my tv which is great bar one problem we are planing to have wooden floors and i dont want the spikes to damage it
    so i suggested we use the castors supplied but no she who must be obeyed
    thinks they look crap so my question is this
    does anybody know of some sort of rubber or plastic studs on the same fitment a the spikes supplied with theese racks
    many thanks
    stu :thumbsup:
  2. stevej
    stevej
    May 21, 2003
    189
    +3
    You might want to try Soundcare Superspike, which can be found here http://www.bkelec.com/superspikes/ . I just put some under my centre (Q95.2c) and the change in sound is quite surprising, namely a whole load mmore bass. Here's the link to the Soundcare site http://www.soundcare.no/ .
