Rubber feet under subwoofer
Discussion in 'Subwoofers' started by Godfather, Jan 16, 2003.
  1. Godfather
    Godfather
    Feb 12, 2001
    2,223
    63
    Edinburgh
    +224
    Hi all,
    As some of you may know, I'm over the moon with my new Velodyne CHT-15 from Uncle Eric. I had a nice chat with him yesterday and he gave me some useful advice about setting up, etc. He suggested that rubber feet under a subwoofer is better than spikes, even though I feel that my Velo is much more wobbly when it's on rubber feet than when it's sitting directly over my carpet (with thick underlay). I've heard the arguments for spikes (e.g. less movement of the enclosure, less wasted energy, greater efficiency, etc). What's everyone else's opinion - rubber feet, spikes, or directly on carpet? And Eric, what's the reasoning behind your preference for rubber feet?
    Cheers,
    Henry
  2. rjw
    rjw
    Sep 6, 2002
    204
    Bath
    +5
    I'm not using the rubber feet on my CHT-15, mainly because they fell off as soon as I moved the sub. They were about as sticky as teflon it seems.
    Currently they are propping up the DVD player, although I might look into putting them back under the sub (with the aid of proper adhesive) when I've finished tweaking it's position.
  3. Spligsey
    Spligsey
    Jan 16, 2003
    2,091
    UK
    +140
    Get yerself down to Homebase & get a pack (or 2) of rubber doorstops (the one's you screw to the floor).
    I have them placed under everything.
    They have sturdied up my gear twofold.
    I even have my monitors sitting on rubber furniture coasters.
    Yet again, sturdyness is the word!
    A very cheap, cheap upgrade.
    Cost me under £10.
    Spligsey
  4. tk2001
    tk2001
    Nov 4, 2001
    1,371
    48
    +36
    I use the rubber feets that came with my CHT-15 and I'm more than happy with it:)
    As long as the rubber feets are placed on an even surface, you shouldn't notive any wobble.
  5. -Spike-
    -Spike-
    May 17, 2001
    1,515
    E.Sussex
    +219
    I've also used the rubber feet that came with my CHT-15
    They do come unstuck quite easily so get it in the right place first and then stick them on
    Thanks again Eric! :)
  6. James45
    James45
    Sep 21, 2002
    2,844
    59
    Taking Care of Business
    i'd use spikes on carpet, rubber feet on a solid flat surface like a wooden floor
  7. cyberman
    cyberman
    thanks for the advice
  8. Godfather
    Godfather
    Feb 12, 2001
    2,223
    63
    Edinburgh
    +224
    Thanks for the replies. Though I'm still looking for the definitive answer (if there is one!).
    I've tried it with and without the rubber feet and I seem to be able to localize the sub more easily without the feet. Could just be my imagination though.
