Ruark Vita100 package
Discussion in 'Home Cinema Speakers' started by helix, Jul 23, 2001.
  1. helix
    helix
    I'm looking to buy a Ruark Vita100 package - driven by an Arcam DV88 and Arcam AVR100 reciever package. Anyone run this combo? Any comments - good, bad or ugly? :D
  2. Ruark Acoustics
    Ruark Acoustics
    We have the Arcam DV88 and AVR100 driving the Vita 100 system as our permanent demo room set up, we highly recommend them!
    Best regards - Rob Pearce UK Sales
  3. helix
    helix
    Thanks Rob - I guess if you work for Ruark I would expect a decent endorsement! I've seen/heard the setup in a dealer's showroom and was impressed which is why I'm interested BUT I want to hear from people who are using them in a real situation i.e. at home! :cool:
  4. paiger
    paiger
    Haven't heard the vita but I have the contempary series and to my ears they are fantastic speakers for the money. Unrivaled clarity and soundstage. Try Sevenoaks, they stock them and will demo them.
    S
  5. -Spike-
    -Spike-
    May 17, 2001
    1,646
    E.Sussex
    +309
    Hi Helix
    I have the Ruark Vita 100 package.Although my player and receiver (Sony 536/Denon AVR-3801) are different to your spec the speakers sound superb.
    Bought from Sevenoaks in Hove.
    No regrets.
    Good Luck in you choice :) .
  6. Russ
    Russ
    Aug 3, 2000
    214
    Warwick, UK
    +16
    I too have the Vita 100 system and find them to be very good - clear, quite neutral and good soundstage. I took back a set of BOSE A15's and bought the Vitas. I found the Bose system to be too bright - sounds good initially, but not really hifi ! So in my opinion, the Vitas are good for music and home cinema. I have just bought an extra pair of satellites to form a 7.1 system.
    Also, they are very flexible in set-up and connection, something you will need with the AVR100, because it has limited flexibility for speaker size/settings. This means that you if you audition the Vitas and like them, get a 'high level' cable (£30) and connect the sub to the front speaker outputs of the AVR100. A good reference is www.aslgroup.com (There are some useful articles on the AVR100)
    I currently use my speakers with a Sony 930 so I would expect that you will get a much better sound with the AVR100.
    My plan for later this year is to upgrade to a TAG AV32R with 7 channel Arcam P25 ammplifier setup - should then really get the best from this sat/sub system !.
    I hope this helps ! But listen to them !!!!
    Russ
  7. helix
    helix
    Thanks guys for the input - it confirms that I'm making the right choice.
    Now - where can I find a dealer to cut a deal on this package which lists at £3300? Sevenoaks may do something if I make a visit (so they say by e-mail) - any other ideas? I'm in Sussex, so forget anywhere North of London. :cool:
  8. tfraser
    tfraser
    here are two contacts for these speakers I was considering myself. Both have the subwoofer as well, both at around £1000
    Mark J. Ryan
    Lintone Audio Gateshead
    7 to 11 Park Lane
    Gateshead
    Tyne and Wear
    Tel. UK 0191 4774167
    Fax. UK 0191 4772771
    and
    Alan Wheal
    Branch Manager
    "Audio-T Southampton" <[email protected]>
    I forgot to mention both demo stock I think.
    Tim Fraser
