Ruark Advice Please
Discussion in 'Subwoofers' started by Stinky985, Apr 2, 2005.
  1. Stinky985
    Stinky985
    Jun 12, 2002
    675
    Nr Bath
    +6
    Just got my Vita 100 (though on the back of the sub it says 120) and have noticed the following:
    1. there is a hum which i think is because i am only using the cheap lead that came with it - i have another on on order.
    2. The auto standby doesnt seem to work. There is no obvious way of telling if it is on or sleeping. Can someone confirm that the LED changes from green when in sleep mode? Its supposed to kick in after 10 mins but i left it for over an hour last night and that light stayed green.
    Can someone help me out?! Thanks.
  2. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    The 2 are probably related as the sub may consider the hum to be of a high enough level to warrant staying in "on" mode.
    Definitely worth trying another cable as it may well solve both problems. :)
  3. Stinky985
    Stinky985
    Jun 12, 2002
    675
    Nr Bath
    +6
    never thought of that! So if i disconnect the lead from the sub, should the sub auto power down if there's no hum? I have ordered a decent subwoofer cable - there are no decent retailers near me, well not ones that charge fairly!
  4. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    I think that should be the case but there's only one way to find out. :)
  5. Stinky985
    Stinky985
    Jun 12, 2002
    675
    Nr Bath
    +6
    yep i have turned it on.. will wait 10 mins and see what happens!
  6. Stinky985
    Stinky985
    Jun 12, 2002
    675
    Nr Bath
    +6
    if a new lead doesnt sort the hum - could it be faulty? It is a noticble hum and only with a lead connected
  7. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    It could be a number of things but I doubt it's faulty. There are loads of threads on here about sub hum, do a search for "Sub Hum" and "Ground Loops" and you should find plenty of information about the source of the hum and ways to fix it. :)
  8. Stinky985
    Stinky985
    Jun 12, 2002
    675
    Nr Bath
    +6
    well i tried it with out a cable and it DID go into standby! your a genius ta! I've read the posts and i reckon a decent lead will sort it - the cheap crappy lead you get with stuff arent good are they and theres lots of other cables around! Thanks again
