Ru970 Philips Colour Remote
Discussion in 'Home Cinema Control & Remote Controls' started by ISHANTY, Dec 4, 2003.
  1. ISHANTY
    ISHANTY
    Sep 13, 2002
    556
    3
    28
    UK
    +66
    all owers of this remote i would like to here you views on this remote control, i want to know what you lik about it and what you don't!!!
  2. Sandman
    Sandman
    Nov 28, 2002
    3,542
    Glasgow
    +1,248
    It is near enough exactly the same as the 890/940 pronto's exept it has a colour screen and a bigger memory for the larger colour bitmaps. They are great remotes and very customisable via your pc. There is lots of files you can download from www.remotecentral.com and amend them to suit your system. The best bet for you is to go to remotecentral and download pronto edit v4.05 and a few files for this remote from their files section (remote is called pronto pro TSU6000 in USA) and you can then use the pronto emulator on you pc to see what the remote can do. I would recoment you download dale crawford's easytheatre ccf. file and danial tonks ccf and have a look at them.
  3. Sandman
    Sandman
    Nov 28, 2002
    3,542
    Glasgow
    +1,248
  4. pizzacheaze
    pizzacheaze
    i think the hard buttons are not as good, but the display is miles better
  5. Mr. Wilby
    Mr. Wilby
    Dec 15, 2002
    641
    +16
    Also keep in mind that the TSU7000 has been released (in limited numbers) state-side, so the European version is only a short while a way.
    Check out www.remotecentral.com for pictures/info. No review there yet, but hopefully very soon.
