RU950 & Sony Amp
Discussion in 'Home Cinema Control & Remote Controls' started by ZippyCat, Mar 19, 2005.
  1. ZippyCat
    ZippyCat
    Aug 9, 2004
    572
    28
    +22
    Hello :hiya: ,
    I received my Pronto RU950 yesterday but I am currently having problems getting it to work with my amplifier (Sony STR-DB940). I have tried to get the pronto to learn the commands, but am having no luck. The main problem is configuring the pronto to allow switching of the inputs on my amplifier. The original Sony remote has a little navigation key that allows you to scroll through a list of inputs displayed on the remote from which you select which device to want. Does anybody know the Hex codes for the following inputs, or indeed a general Hex code that allows you to sequentially switch through the inputs? :
    5.1
    Video 1
    Video 2
    Video 3
    DVD/LD
    TV/SAT
    Tape
    MD/DAT
    CD
    Tuner
    Phono.
    Thanx for any help! :smashin:
  2. ZippyCat
    ZippyCat
    Aug 9, 2004
    572
    28
    +22
    Just to update my request, I now only need the hex code for the 5.1 channel input. Thanx
  3. vizslaraner
    vizslaraner
    Dec 13, 2003
    424
    Hereford
    Try this one . . .
    0000 0067 0000 000D 0060 0018 0030 0018 0030 0018 0018 0018 0018 0018 0030 0018 0030 0018 0030 0018 0018 0018 0018 0018 0018 0018 0018 0018 0030 03DE
  4. ZippyCat
    ZippyCat
    Aug 9, 2004
    572
    28
    +22
    Thanx! :thumbsup:
