Ru7400 no hdr
Discussion in 'Samsung TVs Forum' started by vialli, Jun 18, 2019.
  1. vialli
    vialli
    Jan 8, 2015
    4
    egham
    I had the 50 inch version delivered yesterday and one thing I've noticed is there isn't an option to turn hdr on or of, I had a 6400 series samsung and it was under general then external device manager but on this set its not even a greyed out menu I can't find anything at
  2. zeppelino
    zeppelino
    Jan 24, 2018
    3,909
    134
    UK
    +1,195
    It’s called Input Signal Plus now, within the external devices menu.
  3. vialli
    vialli
    Jan 8, 2015
    4
    egham
    Excellent thanks, I'll have a look after work later
  4. simoncdale
    simoncdale
    Apr 27, 2019
    32
    Oxted
    +7
    I think it's just automatically on. I've watched HDR content without having to change a setting.
  5. zeppelino
    zeppelino
    Jan 24, 2018
    3,909
    134
    UK
    +1,195
    It’s automatically on for built in apps, but I believe it needs to be enabled for sources connected via hdmi.
  6. simoncdale
    simoncdale
    Apr 27, 2019
    32
    Oxted
    +7
    Ah ha, you might be right there. I'll also have to check when I get home
