RSX-972 question
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by dreamc, Jul 13, 2004.
  1. dreamc
    dreamc
    Jun 10, 2004
    61
    +3
    I've had this Rotel amp for quite a while and every couple of months the manual comes out when i need to add/change something. Everything is working fine, but i was wondering about one thing. In the manual it says under the other options menu :
    5.1CH: determines whether or 5.1 channel input is turned ON or OFF...but if i switch this on i hear no sound.....so why is this used? Pre-amp?
