Rs232 on Digibox to change channels??
Discussion in 'Satellite TV, Sky TV & FreeSat' started by jonhopkins, Dec 16, 2002.
  1. jonhopkins
    jonhopkins
    Dec 16, 2002
    2
    I'm trying to use digiguide (www.digiguide.com) to automatically record off sky digital to divx via virtual dub on a scheduled basis.
    Everything is working fine with the exception of control to
    the digibox. Yes, personal planner does work, but I really want
    to automate the whole process.
    Does anyone have any information on how to do this. Yes it is
    possible as satcure sell a digimemo which does something similar
    (for £70), but there is no direct link to the Pc.
    thanks,
    Jon
  2. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,279
    Manchester
    +762
    Up to now the serial (RS-232) port on $ky Digiboxes has only been used for factory-based functional tests.
    The rumour is that it may soon have a real user function - but that's only a rumour right now.
    I'll tell you more (if I'm allowed to) after my next visits to the design dept. at Pace.
    Chris Muriel, Manchester.
  3. dpoulson
    dpoulson
    Dec 10, 2002
    30
    Lancaster
    I've been trying to find out abou this too. I want to have a go at building my own PVR, but it wouldn't be much use without being able to change the sat. channel!
    Ideally I'd be able to change channel with a simple serial console command.
    Anyone else any ideas?
  4. Fernsehman
    Fernsehman
    I think you may be discussing the 1394 digital interface socket.
    A long time ago Pace implemented a software "upgrade" which puts a 5 minute time-out on this factory test/programming socket, which makes it useless for any control usage.
    See
    http://www.satcure.co.uk/digifaq2.htm#computer
    However, it's easy to control a Sky Digibox via the RF2 socket, just as the various "Digilink, SLXlink, TVlink" remote extenders do. You just have to find out the carrier frequency and the data mode!
    Fman
