rs100 bracket + LG RZ-42PX11 ???
Discussion in 'Home Cinema Buying & Building' started by tabs, Apr 25, 2005.
  1. tabs
    tabs
    Apr 3, 2005
    1,918
    warks
    +130
    does the rs100 bracket (non tilt, £69 jobby) need the extra depth bars for the LGRZ-42PX11 ? thankyou
  2. JohnCCFC
    JohnCCFC
    Feb 18, 2005
    417
    +10
    Can't comment on these items specifically, but I think that if the sockets come out of the back, then yes, if the sockets come from underneath, then not necessarily.
  3. tabs
    tabs
    Apr 3, 2005
    1,918
    warks
    +130
    cheers john, as im still awaiting delivery of the screen, ive not got a clue where the sockets are, help
  4. JohnCCFC
    JohnCCFC
    Feb 18, 2005
    417
    +10
    ask other LG owners, they'd know
  5. RexConnix
    RexConnix
    The scart sockets are inlaid on the back but do stick out, as for all other connections they are all underneath apart from the S-video/comp which are on the side. Hope this helps
  6. zorg
    zorg
