rs fx position question
Discussion in 'Home Cinema Speakers' started by rob virgo, Aug 3, 2006.
  1. rob virgo
    rob virgo
    Nov 27, 2004
    218
    16
    hi ,
    I have just collected my new yamaha 759se and ma rs fx speakers.I am recabling the entire system as well so am busy in todays heat.
    Question is what way should i mount the fx pair,on the rear wall or sides.I have a converted roof space so looking back down the room from the screen you can see the back wall is triangler shaped.room has a vaulted ceiling so if i mount on the side walls they will be at ear height close to listening position.
    the preferred position i think is the rear wall but how high and how close together.
    cheers for any ideas:smashin:
    rob
  2. rob virgo
    rob virgo
    Nov 27, 2004
    218
    16
    anyone able to offer help
    cheers
    rob
  3. phils_wicked
    phils_wicked
    Mar 11, 2003
    563
    Luton (UK)
    +16
    Either could work well, I prefer speakers on side walls behind and slightly above my head.
    If I were you I would experiment before settling on a position. (and then tell me, because Im looking to get a pair of these lol)
  4. rob virgo
    rob virgo
    Nov 27, 2004
    218
    16
    phils ,
    I will play around with them over the week end and let you know.i ran the yamaha auto set up and found the sub was over driving with the volume cranked up.i had to knock it back a bit.
    cheers
    rob
  5. phils_wicked
    phils_wicked
    Mar 11, 2003
    563
    Luton (UK)
    +16
    Nice one.
    It really is worth trying out different speaker positions, they can sound so much better with experimentation.
    If you could let me know how you get on and what you think to the RS sfx I would be greatfull.
  6. rob virgo
    rob virgo
    Nov 27, 2004
    218
    16
    phil,
    i havent forgotten to check fx positions.just up the walls .bear with me
    cheers
    rob
