RS-232 to a Panasonic TH-42PA50E?
Discussion in 'Panasonic TVs Forum' started by starcat, Aug 10, 2005.
  1. starcat
    starcat
    Aug 8, 2005
    266
    +19
    Hi there,
    I have bought the following SD panel to overcome the time until a true 1920x1080 panel comes out (the 30" Apple display is too small for me) but have found out that it doesn't have a RS-232 control port which I need for my control system.
    Do anyone know if there is a possibility to add it or a mod or any other posibility of dual way control? The last resort would be the IR control with some discrete codes (at least selection of aspect ratio, component/s-video input selection and power on/off -- I am using it as a monitor device only).
    TH-42PA50E
    SD Panel (852 x 480 Pixel)
    HDTV-compatible 576i, 720p, 1080i (50, 60 Hz), no HDMI connection
    PC-input (VGA): No
    Mucho thanks,
    Bob.
