RS 232 socket
Discussion in 'AV Receivers & Amplifiers' started by Neil69, Nov 26, 2001.
  1. Neil69
    Neil69
    Jun 8, 2001
    316
    2
    15
    Leigh
    +17
    I have had a Yamaha DSP-AX1 for 12 months now & I was wondering what the RS 232 socket is for on the back? The instruction manual doesn't say anything much.
    :confused:
    Cheers, Neil
  2. Vis Man
    Vis Man
    Feb 22, 2001
    207
    UK
    +10
    Hi Neil
    RS232 is a control port. A simple Example would be to connect your amp to a Crestron system (expensive but excellent r/c) which would send commands to your amp to switch inputs, volume control stuff like that.
    cheers
  3. MarkB
    MarkB
    Oct 29, 2000
    737
    Suffolk, England
    +26
    - Or link it directly to a PC and control it from a Terminal program
    - Also, sometimes, minor upgrades to the system software can be performed through this port.
