RS 232 library for RTI
Discussion in 'Home Cinema Control & Remote Controls' started by Gonzi, Jan 8, 2012.
  1. Gonzi
    Gonzi
    Oct 12, 2006
    57
    I would like to know how to get these RS 232 remote commands into the RTI Software
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,570
    Edinburgh
    +1,268
    You would use the RTI RS232 library manager, create a new library if you haven't already got one and then create the product and add the codes in there.
