RS-232 Control for HT300 XTRA
Discussion in 'Projectors, Screens & Video Processors' started by sammck, Apr 8, 2005.
  1. sammck
    sammck
    Apr 8, 2005
    Seattle, WA
    :lease:
    Can anyone tell me where I can find documentation on the remote control protocols through the serial interface? I want to control the projector from HTPC software, and do something more reliable than throwing unconfirmed IR codes at it. The manual suggests that the interface supports remote control as well as upgrade, but I can't find a description anywhere.
    Thanks,
    Sam
  2. sijones
    sijones
    Nov 5, 2001
    632
    Reading
    +34
    Hi Sam,
    If you PM me your email address then I will send you a document which describes the RS-232C control specification for the HT300.
    Regards,
    Steve
