RPTV setup advice.
Discussion in 'General TV Discussions Forum' started by JIT, May 8, 2002.
  1. JIT
    JIT
    Mar 2, 2002
    1,195
    38
    Glasgow
    +8
    I have just ordered a Toshiba RPTV and as this will be my first RP I would appreciate any advice from RP owners as to achieve the best picture quality available.
  2. Kevo
    Kevo
    Aug 23, 2001
    5,448
    Manchester
    +166
    Don't know if you have Digital TV and/or DVD, but if you do always use good quality SCART leads and always use Component/RGB settings.
    Composite looks AWFUL, whilst S-Video is a good compromise.
    Leave the TV on for about 45 mins before making any adjustments.
    Are you colour blind?
    (Most males are!)
    I am on reds and greens and really struggled with the convergence settings, so it helps if you have someone to assist or even just to give a second opinion.
    Not much more I can think of really.
    Be prepared to be gobsmacked at the pic quality on DVD, but only if you use RGB.
    Enjoy.
