Kenny Saxman
Hi There,
I just wanted to share this information with you.
Problem - HD channels on YouView (BTvision) such as BBC News Channel freeeze block lose signal retune results in channel being lost completely. All other HD tv's in home receive fine no problem.
Due to 700MHz frequency sell off by the Government free view channels have been shuffled around in the UK, my local transmitter Rowridge is supposed to be a group or band A transmitter horizontally polorized, however last April they moved mux 7 and 8 way up the TV spectrum to channel 57 from memory, band A stops around channel 37, not only this but they changed the polorization from H to V (vertical). Many Rowridge households will as a result lose mux 7 and 8 the HD channels if they have a band or group A aerial or a group A band pass filter in their aerial system (filters were fitted to fix you view box issues in the past).
If you have a HD TV and connect it directly to the room aerial point and you can retune it and recieve the mux 7 and 8 transmissions but fail to get the youview box to detect them on a retune, then there could be a simple fix, this was the problem I had. I purchased a full band 0 - 20 dB variable attenuator from Amazon. I set the adjuster to about half way and placed it in the aerial wall socket feeding the you view box and carried out a retune, I got all channels immediately I then set the youview box to channel 107 (BBC News) and selected signal Quality. The recieved signal strength was at about 40% I adjusted the attuator to get a 90% signal.
I have had this installed for about a week now and have been problem free on my youview box for the first time since last april, no channels are blocking or freezing and reception of all channels is stable.
The problem is due to too much of a good thing the signal strength is so high the cheeper decoders used by humax simply cannot decode the mux channel info and ignore it.
I live in Lyndhurst so if you are nearby and need some help I would be glad to offer some assistance or advice, no charge. I am an Air Traffic Control Voice Comms radio station systems specialist so have a reasonable knowledge.
I just hope this post helps, on the other hand you can wait a couple of years until they shift the Mux 7 and 8 back down to a group A channel.
All the best Kind regards
Kenny
Kenny
