Routing video signals via amp, PS2/Xbox, cable questions and plenty of them
Discussion in 'Cables & Switches' started by potfish, Jun 12, 2003.
  1. potfish
    potfish
    Apr 8, 2003
    389
    Bristol
    +5
    Thanks to the recent acquisition of a PS2 for free :) I decided it is a good time to reconsider how everything's wired up.
    Current system:
    Sony Wega widescreen, has 3 SCARTs of which 1 is RGB-capable and 1 is SVHS-capable
    DVD goes straight to TV's RGB-capable SCART connector, using RGB
    VCR goes to cable box with SCART cable, cable box goes to TV's SVHS-capable SCART connector (only using composite though)
    XBOX goes to TV's third SCART using crappy cable supplied (i.e. composite)
    To use the PS2 requires unplugging something.
    I have a Pioneer 2011 amp which currently has none of its video connections used (actually I have its output wired to the VCR now so via a long winded route at least I can use the setup menus when I have to).
    So what I think I want to do is the following:
    Leave DVD as is.
    Buy SVHS to SCART cable for amp to TV.
    Buy PS2 to SVHS cable for PS2 to amp.
    Buy XBox to SVHS cable for XBox to amp.
    Buy composite to SCART cable for amp to TV.
    Buy SCART to composite cable for cable box to amp.
    Leave VCR connection as is.
    Configure amp to switch the video sources (except DVD) to the TV as appropriate.
    Note: TV, XBox and PS2 will be close together but remote from the rest. Maybe 3m cables will do it but would prefer to use 5m ones to be sure.
    Questions:
    Does this sound sensible?
    Can I buy one cable to do both SVHS and composite from the amp to the TV?
    Is there any benefit to using digital audio connections from the consoles to the amp? (I don't use either for DVD and don't have too many games for either yet).
    Would there be a real benefit to using RGB from either of the consoles, considering I'd need to buy even more cables for rerouting the DVD via the amp? (the 2011 amp has 2 component inputs so it could only be DVD plus one console.) Would I see a degradation in DVD quality for routing it through the amp?
    Where can I buy all the above cables, especially the ones for the consoles? Seen plenty but not at 5m length.
    Thanks for your advice.
    potfish
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Very sensible mate
    Oh yes quite few games have DTS/DD 4.0 for cut scenes etc Why dont you use digital for DVD???
    I have only compared RGB and composite so can't really comment on S-vid compared to RGB
    Try the console forum but QED make games console cables so do monster etc also try game etc
  3. potfish
    potfish
    Apr 8, 2003
    389
    Bristol
    +5
    Blimey that was quick!
    Ah yeah, I do use digital for DVD, I meant I don't use the consoles for DVD.
    Can anyone tell me where I can buy a decent 5m SVHS+composite to SCART cable then?
    Thanks for the answers, I'll see if anyone can help me source the long console cables in the console forum.
    potfish
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Lektropacks
    They make custom cables so should not be a problem might cost a bit though.
  5. potfish
    potfish
    Apr 8, 2003
    389
    Bristol
    +5
    Will check them out, thanks
  6. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,665
    Bristol.
    +309
    www.intoav.com
    I use an evolution S-video lead and the quality is great.
    Note that if you route the consoles onto the amp and switch, you only need one cable out from the amp dont you.
    Cap:smashin:
  7. potfish
    potfish
    Apr 8, 2003
    389
    Bristol
    +5
    Thanks for the link.
    I need both composite and S-Video from the amp to the TV if I want to use S-Video for the consoles and composite for cable/VCR. The amp can't convert between the two.
  8. cbemoore
    cbemoore
    May 16, 2002
    1,295
    38
    Esher
    +16
    Unfortunately that won't work.
    Composite uses the same Scart pin as the SVid luminance signal. So you'll either be able to get a composite->scart, or a Svid->Scart, but not both at once!
    I suppose you could get a cable made up with a switch on it, so you could use it for either. But that would be a pain......
    Chris
  9. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Pot fish does AV 3/4 side input on your sony have composite and S-vid iof use this for the 2 cable from amp
    PS S-VHS is not S-Video (S-VHS is a an anlongue recording fromat like VHS and betamax) S-Video is a video standard like RGB and composite (PAL).
