router question (real basic 1 at that)
Discussion in 'PC Gaming & Rigs' started by mr ooops, Aug 3, 2005.
  1. mr ooops
    mr ooops
    Mar 4, 2003
    3,657
    103
    Hardwicke and Wotton
    +349
    Hi all
    my telewest broadband modem is one room and my pc is in another (40 ft apart) i normaly just trail a network cable around the skirting, but the wifey wants to decorate and dont want the cable showing :(
    so realy all i need to know is if i buy a wireless router and plug my modem into that and use my wireless card on my pc in a different room will it work? or do i have to have a pc in the router to make it work?
    (see i said it was a daft basic question)
    regards
    jason
  2. jenic
    jenic
    Dec 10, 2004
    2,901
    83
    +178
    You need to connect the router to set up the connection but you can then just use it for wireless.
  3. HMHB
    HMHB
    Nov 11, 2001
    26,631
    Nottinghamshire
    +5,335
    Yes, as long as your broadband modem has an ethernet connection, you just connect that to your wireless router and away you go.
  4. mr ooops
    mr ooops
    Mar 4, 2003
    3,657
    103
    +349
    nice 1 :) i'll order a router now i know i can do it :)
    cheers
    jason
