Router problem
Discussion in 'Xbox Forums' started by PhilNUK, Mar 13, 2006.
  1. PhilNUK
    PhilNUK
    Dec 30, 2005
    881
    28
    +25
    Hi guys
    I have a 360 and a Linksys WRT54G router.... it all works fine, apart from one thing. I have to have the PC booted in order for the 360 to access Xbox Live.
    Which isn't particularily convenient as the PC is upstairs.
    I am sure I never had to do this before, but last week I set up the router with my new PC and had to reset the router and since then I have noticed this problem.
    Anyone know why this is happening? is there an option I need to choose in the router settings?
    cheers for any help
  2. mminghella
    mminghella
    Dec 16, 2005
    1,067
    48
    Liverpool
    +34
    That does sound very odd.
    Is your router set as the DHCP server? That could explain why you need the PC as it might try to set the IP address for you 360.
    Just a thought
  3. ShadowmanUK
    ShadowmanUK
    Feb 14, 2006
    1,299
    63
    +132
    Yeah its likely to be an ip address thing. There's no reason at all why your PC needs to be on.
  4. Radioactive__Man
    Radioactive__Man
    Jan 13, 2001
    967
    Scotland
    +18
    agree with above, done it myself
