Router ports
Discussion in 'Networking & NAS' started by technique786, Jan 6, 2012.
  1. technique786
    technique786
    Dec 20, 2011
    311
    +8
    Hi guys,
    Im like a child in this forum just more and more questions.
    So i have calculated all me new equipment has sent my router over the edge. I have a 4 port router and i need a total of 5-6 (depends if V+ box needs networking)
    My question is what is a good router with that number of ports and if i get a "switch" would the things connected to it be slower (would they be sharing one connection so to speak)
    Im am useless at this stuff but am building a new living room for myself and want to get it right.
    Thanks for all the help.
  2. rednotdead
    rednotdead
    Jun 4, 2005
    462
    28
    Hampshire
    +44
    Just get a gigabit switch. Don't worry about speeds etc - for that number of devices your're not going to have any problems.
    Lots on here recommend TP-Link. I've not used those personally, I prefer Netgear.
  3. charles_b
    charles_b
    Apr 28, 2006
    616
    Berkshire
    +91
    Most Home routers only provide 4 ports (plus a WAN Port for access to your Internet gateway).
    If you want to extend the number of ports, then get a 4, 6 or 8 port switch. Chances are that your router is 100Mbit in speed, you just plug one cable from your router into the switch and instantly extend your number of ports (albeit losing 1 port on the router and 1 on the switch)
    Don't buy a Hub, as this shares the bandwidth, you must buy an unmanaged switch, most home ones are perfectly respectable from a known manufacturer, e.g.:
    4-port TPLink £14 from Amazon: TP-Link 5-Port Gigabit Unmanaged Desktop Switch (TL-SG1005D) Plastic Case: Amazon.co.uk: Computers & Accessories
    5-port Netgear £15: Netgear FS605 Platinum Series 5 Port 10/100 Unmanaged Switch: Amazon.co.uk: Computers & Accessories
