Hi all, Right Ive learned from here about a strategy against things invading/infecting/hijacking ones computer, as far as internet connections are concerned and Im buying a new laptop to start from scratch and hopefully minimise my exposure to the perils of viruses and spyware - internet use generally. So apparently using a router is a hardware-based mode of protection (to complement the other methods, of course) and so Ive ordered this - http://www.solwise.co.uk/adsl-sar600e.htm - and am hoping that it will work. And hoping also that it is the most appropriate for my needs given that we will only ever want one computer connected to the internet at any time (although does having this router then mean that in future another computer upstairs could use the same broadband connection? With say a wireless transceiver set-up?) Ive got an ADSL broadband connection and am going to be running a Toshiba Satellite L10 laptop. I hope its as simple as simply inserting the router into this equation? Thanks a lot people having already helped me out with RAM-upgrade queries. Arif
yep, that will do for what you need. In the future, if you get a wireless setup, just plug the ethernet connection on the router into the ethernet connection on your wireless gear.. In all honesty though, if you have a few extra quid, I'd cancel that order ( solwise are usually OK with this) and get yourself a Netgear DG834G you should pick one up for about £60.. This is a better router, with a very good firewall, is a doddle to setup, and is a wireless access point too... a one box solution, and definitely an improvement over the SAR due to the extra connectivity.... - and it looks nicer..
Another vote for the Netgear router. Seems to do the job and (reasonably) easy to set-up. I've recently started using the wirless network element having bought a Netgear usb wireless adaptor for my HTPC down in the garage (router upstairs). Again this worked firstime so no complaints from me. Ray
I would also say to cancel the order and get a modem router. You get 4 ethernet ports and wireless so if you wanted to have another computer upstairs, you could have both computers sharing the same Broadband connection. Personally, I'd have the upstairs computer connected via ethernet and the laptop via wireless. Laptops are made to carried around so there's no point tying it down with an ethernet connection. Richie.
A good router will stop unsolicited connections to your network but Just putting in a router is gonig to do virtually nothing to defend against spyware and viruses. You'll still need AV and AS/W software installed for that.
