Router and a cable connection
Discussion in 'General Chat' started by dUnKle, Feb 4, 2009.
  1. dUnKle
    dUnKle
    Jan 1, 2001
    15,930
    +2,920
    Friend from work wants to get himself a wireless router so he can have more freedom online
    He currently gets his Broadband (along with TV and the like) from Virgin using a cable connection. Because of this I belive he needs a cable router (unlike mine which is a bog standard modem router)
    Is the procedure for installing though still the same ?
    Think he is going to get a Netgear Netgear WGR614 would this work ?
    I take it cable routers work completely differently then to normal ones ?
    I have the non cable version of the router mentioned in post 1
    For me its
    Connect to phone line
    Connect my laptop / pc to the router
    Run the "auto detect" set-up
    Enter my broadband login and password
    and thats it
  2. Iccz
    Iccz
    Apr 29, 2008
    24,060
    Keystone City
    +6,750
    Cable router has a RJ45 WAN input instead of ADSL's RJ11
    They work the same inside and use the same principles.
  3. Ben
    Ben
    Feb 19, 2007
    1,417
    Tunbridge Wells
    +263
    Pretty similar, yes.
    Yep :)
    The main difference is that rather than connecting the WAN port on his router to the phoneline as you do, he'll connect it to the cable modem that Virgin Media supply. As Iccz mentioned, it requires just a normal network cable with RJ45 connections to connect the two.
  4. dUnKle
    dUnKle
    Jan 1, 2001
    15,930
    +2,920
    Ah
    starting to see now
    So he retains his Virgin Modem as he has now and the connects the newly purchased router to this via network cable ?
    Would he have to confugure the new routers settings (as I do with mine) or does it just take them off the cable thing ?
    Basically he just wants to be able to use his 360 and laptop via wireless
  5. grey fox
    grey fox
    Mar 18, 2006
    613
    46
    +122
    I am with Virgin too, and to use my router with the modem I didn't have to enter any settings at all on the router. However it might be a good idea for your friend to check in the instruction manual for the router to make sure.
    One thing that your friend must do though is make sure that he reboots the modem after connecting it to the router and once this is done hopefully he will be sorted.
  6. Iccz
    Iccz
    Apr 29, 2008
    24,060
    Keystone City
    +6,750
    Chances are if he's buying a router it'll come with a modem built in, you might want to just ditch the old modem if the router/modem combo works ok, if not just have the router doing the job of routing, the RJ45 from the modem goes into the uplink port on the router and once DHCP etc is enabled anything connected to the router will be assigned an IP and can connect to the internet via the modem, if you just use the modem/router combo on its own that will connect to the internet and do the local routing.
  7. dUnKle
    dUnKle
    Jan 1, 2001
    15,930
    +2,920
    Well he has ordered the Netgear WGR614 so not sure how that leaves him
    Never had experiance of cable before, my town dont get it
  8. JonMace
    JonMace
    Nov 20, 2002
    2,577
    83
    Kent
    +211
    Cable Routers do not come with a modem built in
    He will either have to reactivate the connection (user name and password) on the VM web site or Clone the MAC address of the PC that is currently connected
  9. Ben
    Ben
    Feb 19, 2007
    1,417
    Tunbridge Wells
    +263
    No chance of ditching the existing cable modem I'm afraid. ADSL/BT modems are designed to be connected to a phoneline & DSL/cable modems connect to the incoming cable (coax). You can't buy routers with DSL/cable modems built-in.
    Dunkle, as Grey Fox says, if he just follows the instructions, it should be piece of cake. He'll be up & running within ten minutes :)
  10. Iccz
    Iccz
    Apr 29, 2008
    24,060
    Keystone City
    +6,750
  11. Ben
    Ben
    Feb 19, 2007
    1,417
    Tunbridge Wells
    +263
    Sorry, I shouldn't have said you can't get them. You can in the U.S. & other countries, but not in the U.K. Even if you could ship one over here, it's against Virgin Media's T&Cs to connect any third party equipment directly to their network.
  12. Iccz
    Iccz
    Apr 29, 2008
    24,060
    Keystone City
    +6,750
    Fair enough, i've never had the need to look to much into them, I stand corrected.
  13. IronGiant
    IronGiant
    Jun 7, 2003
    66,485
    +46,684
    As a slight side issue, (hope you don't mind me asking, dunkle) our cable modem is apparently getting a bit flaky in its old age. Do the Virgin V+ boxes have a cable modem built in and if so is it a simple matter to swap over to it?
    Dave
  14. Newton's Ring
    Newton's Ring
    Apr 26, 2005
    546
    North-West
    +65
    I'm a Virgin and I used to have a Netgear WGR614 v4 (58mbps) - worked a treat. I sold it recently and bought another Netgear (I forget which model) - 108mbps - it seems faster and the range is noticably better (the 614 wasn't great for range).
    I've done installs for others on a BT line (via various 3rd parties) before and find the cable versions much easier, troublefree and easily swappable whereas with an ADSL line you might run into problems if you want to upgrade the modem (MAC address probs).
  15. Ned Senior
    Ned Senior
    Aug 14, 2006
    4,818
    Stalag 9
    +1,170
    Hi I had cable for about ten years.. as long as you have a dedicated cable router you take ethernet out from the virgin modem to the ethernet IN on the router then there are usually 4 ports to connect other ethernet cables to your pc's and ps3's etc. also there are wireless versions available which still have the 4 ports out BUT also can connect wirelessley some models are more easy than others to set up via wireless getting the pc's to connect with wep/wap encryption to keep your network secure from bandwidth thieves and spies
    I had a linksys and it was a bitch it kept dropping the connection to the wireless pc!!!
    Much prefer a wired network personally but then my flat is not massive and was easy to setup although my son has a imac and ps3 connected wireless to the modem router that o2 sent out when I jumped off wirgin and went to adsl
  16. Ben
    Ben
    Feb 19, 2007
    1,417
    Tunbridge Wells
    +263
    Hi Dave. IIRC, the V+ does have an integrated modem, but the firmware on the V+ doesn't allow you to use it. I'd suggest giving faults a call & get them to send a replacement modem. Bearing in mind you rent the equipment, it should be FOC. My remote stopped working recently & they sent one no probs :)
  17. DVD-Man
    DVD-Man
    Jul 24, 2004
    8,580
    Ayrshire, Scotland
    +1,932
    I've got one of these and it is indeed an all in one solution but it's only configured to pick up US Broadband!
    The UK will seem some to the end of this year, I am desperate to get one, you can get one right now from the US, search Ebay for Surf board motorola and look for one with an etc little bit sticking out the top, that will do Eurodocsis but is about £100 to get and ship over here.
    Liam
  18. benwillcox
    benwillcox
    Sep 21, 2004
    295
    Telford
    +22
    I'd advise ringing Virgin and get a price for a wireless router through them, friend of mine just got a Netgear wireless router via Virgin for £7.50 due to him already having Virgin cable, so cheaper than buying the router from a normal retailer.
    Cheers,
    Ben
  19. Ben
    Ben
    Feb 19, 2007
    1,417
    Tunbridge Wells
    +263
    Out of curiosity - what are the benefits of having a combined cable modem/router, apart from neatness?
  20. Cyland101
    Cyland101
    Feb 1, 2007
    883
    +87
    I had issues with my Virgin cable modem just after new year with intermittent connectivity problems. I called support and the support person said that he would ship one out to me. 1 week later it never arrived, so I called again and spoke to a different chap. He basically gave me the option on having another one sent out or to get a engineer to come round the next day. I booked the engineer, he came round on-time, and swapped it out with the comment that my cable modem was way old.... (i had that one for 8+ years)
    So I guess what I am saying is get the engineer round as they carry spare modems with them.
