Rotel's RSP-985 replacement
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by marcoeser, May 5, 2001.
  1. marcoeser
    marcoeser
    Jul 17, 2000
    342
    On Rotel's web site the RSP-985 preamp /processor is listed as discontinued. Does anyone know about the replacement model?
    :confused:
  2. pc39707
    pc39707
    It looks like the replacement for the 985 will be the RSP-1098. It will have 7.1 DD, THX-EX and DTS (ES?). Available in july?
    /Jon
