Rotel RSX - 1550 vs Rotel RSX - 1562
Discussion in 'AV Receivers & Amplifiers' started by Mikez12345, Aug 16, 2018.
Tags:
  1. Mikez12345
    Mikez12345
    Aug 16, 2018
    SF, CA 94111, US
    Hi I have a Rotel RSX 1550 which is connected to Vandersteen 2CE Sigs in the front, Vandersteen VCC center, Vandersteen 2CI’s as rears, and two martin logan 10 inch subwoofers. I recently found someone selling a Rotel RSX 1562 for $200 on CL. At least to my ears the Rotel/Vandersteen combo sounds amazing for music and movies. My questions are as follows:
    1.) Does it make sense to upgrade? I think there’s a good chance I could sell my 1550 for more than $200
    2.) What’s the real difference between D and A/B - I guess my question is does the 1562 sounds any worse or better?
    3.) For video I’m running the HDMI directly to my TV and using a 4K 60Hz HDR 1x2 HDMI 2.0 splitter, which sends HDMI audio to my Rotel as I wanted 4K on my TV. As a result I don’ t think the HMDI 1.4 does anything for me.
    4.) In terms of codecs or sounds formats (DTS, etc) does the 1562 offer anything extra?
    Thanks,
    Mike
  2. Mark.Yudkin
    Mark.Yudkin
    Sep 19, 2007
    10,067
    Zurich, CH
    +1,551
    The RSX 1562 gives you HDMI 1.4 and HD audio formats. It does not support HDMI 2.0 / HDCP 2.2 and hence will not pass your UHD signals.
    You are unlikely to find a functioning UHD-capable AVR able to drive your Vandersteens at $200.
    If you really can switch the 1550 for a 1562 at zero cost, the "should I upgrade"? is rather a no-brainer. :)
