Oldbillgoggles
Established Member
I hope someone can help me with this.
I have just bought a Rotel rsx 1067 from a popular auction site. On testing, it seems prone to tripping the circuit breaker, when powering on at the master power switch.
I did some short tests on the unit this morning -
I only have a stereo speaker set up, so I was checking each analog multi channel input from my blu ray player, to test each amp sequencialy. It all seemed to work. However, when I switched the master power switch off, it tripped the circuit breaker.
I have tried turning the master power switch on and off some 30 times, with nothing connected to the receiver - and it has tripped the circuit breaker around 5 times.
The manual says the unit is designed to be left in standby mode, so I'd like to know if this is normal behaviour, or if there is a likely fault with the receiver.
The seller agreed to a 1 week test period, to allow for a refunded return if I found any faults in the unit.
I'd be very grateful for any advice, as it sounded very nice on testing with stereo Quad 21L speakers.
