Rotel rsp1066
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by Patrick vdb, Jun 3, 2002.
  1. Patrick vdb
    Patrick vdb
    May 31, 2002
    14
    Maastricht / The Netherlands
    Does anybody in the UK has experience with the Rotel pre/pro RSP1066? In Holland this processor is just available in the av-market and therefor experienced people are hard to find. What can be said about this processor? How does it perform and what's the character of this equipment (laidback sounding, agrresive, warm or neutral?)
    Best regards,
    Patrick
  2. garmtz
    garmtz
    Mar 27, 2002
    305
    Netherlands
    Hello Patrick,
    Rotel sounds a bit laidback, "creamy" and warm, but always very musically satisfying and pretty dynamic. It always has a "nice" sound which can make most recordings sound good. With the best recordings, something could go missing though.
  3. Patrick vdb
    Patrick vdb
    May 31, 2002
    14
    Hello Garmtz
    Never expected to speak to a dutchman on this forum:D
    I've listened to the Rotel RSP985 and 976 a while back (the 1066 wasn't out then) and these also sounded laidback. For music or movies with a certain ambiance it worked really good but with action-packed movies I missed a bit of aggresion unfortunately. This bit of aggresion I found in the Denon AVC-A1SE but this one lacks a bit of the dynamics of the Rotel's RMB1095 amp (which I surely liked). Difficult choice.
    Perhaps that the newcomer 1066 had a bit of the aggresion which I missed in the former processors of Rotel but this is very unlikely I understand.
    Best regards
    Patrick
    ps. I will post any further questions on the dutch HTforum (praat wat gemakkelijker;)) if I have them.
