Cocksure
Hi all,
I recently got a Rotel RSP-1570 (thanks to folks on this site pointing it out to me
) and whilst I am very pleased with the sound quality (and having DVD-A back
), I am having nothing but trouble when it comes to the HDMI output
It doesn't matter what hdmi output setting I pick in the rotel menu, as the signal I recieve at the display is I'ver out of range if fed a 1080p signal or some thing like 486 by 576 if feed a 576 signal (all signals via hdmi). However bring up the rotel menu and it outputs 480p fine to the display
Does anyone have any idea whats up?
Note, one more thing that might be important. when i feed the amp a HD sound signal (dts hd, etc) and use the Rotel to output the video, not only do i get out of range but I also lose the audio, however if I change nothing on the rotel but instead feed my projector directly from the PC graphic card (in clone mode and swap the input choose on the PJ), then the sound suddenly works fine.
Edit, should just add Rotel has been updated to latest firmware and PJ gives incorrect EDID readings
