Rotel RB971 Fault
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by AdrianH, Aug 27, 2006.
  1. AdrianH
    AdrianH
    Nov 20, 2005
    97
    11
    I have an issue where I have just sold a Rotel RB971 mk2 set to Bridged Mono mode and was working perfectly in my set up before despatch to it's new owner. Unfortunately when the buyer fired it up at his end and 'ear splitting hum' was emitted from the speakers.
    Has anyone any ideas what could have happened here?
  2. sdb123
    sdb123
    May 17, 2005
    18,182
    2
    Rushden, Northants
    +2,252
    I take it that the 971 is a power amp....is the new owner running directly into it instead of through a pre-amp?
  3. chachi
    chachi
    Perhaps one of the bridging jumpers popped off internally in shipment (?)
  4. AdrianH
    AdrianH
    Nov 20, 2005
    97
    11
    RB971 is a power amp, and yes the new owner is running through a Pre-Amp, I am getting the Amp sent back so will check the jumpers when I recieve (must admit this was one of my thoughts).
    Should get it back about mid-week so will keep you updated on my findings....
  5. chachi
    chachi
    Perhaps he didn't wire it up properly to the 'outside' posts ...
  6. AdrianH
    AdrianH
    Nov 20, 2005
    97
    11
    Hi guys,
    Just got the amp back and checked out jumpers (ok) and made sure it is correctly wired up and yes we do get this 'mains hum'. I have just had a look round inside and everything seems to be ok, I am at a loss as to how something like this happens in transit as it looks virtually bomb proof?
    Any suggestions or recommendations of a good repair shop around the Derby area?
    Many thanks
  7. AdrianH
    AdrianH
    Nov 20, 2005
    97
    11
    I've just put back to stereo mode by moving jumpers back to 'factory settings' and was about to hook up to my processor and wondered if there is a possibility of doing some damage to the processor/speakers - any feedback would be most gratefully received.
  8. morksbeanbag
    morksbeanbag
    Jul 25, 2004
    723
    Chesterfield, Derbyshire.
    +49
    Doubt you could damage the processor, but don't use your best speakers, find something cheap to use as a test.
  9. chachi
    chachi
    In addition to using cheap speakers, have you got an old VCR or cassette deck lying about for a direct source?
    Wouldn't use/risk a processor or 'good speakers' for this IIWIYS ...
  10. AdrianH
    AdrianH
    Nov 20, 2005
    97
    11
    Did that in the end and the amp worked fine so hooked up to 'good' speakers/source and RB03 and it worked fine again (and sounded better ;) )! :thumbsup: ran it for two hours without a hitch so swopped jumpers to mono format and that went ok also!
    So all in all a good result - my guess is that the guy must have had a short on his speaker connection giving the 'hum' - thing is it cost me a sale and a fair few bob on paypal/ebay charges.....
    Many thanks for all your help - just about to post next query on my new 1066/1075 combo!
    AdrianH
