Rotel RB 1066 - 5 channel operation
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by grey torq, Oct 15, 2004.
  1. grey torq
    grey torq
    Jul 13, 2002
    394
    28
    +26
    Probably displaying my ignorance but the descriptive blurb for this 6x60w amp refers to 5x70w operation. I can see no reference to this in the manual, is it simply the case that if you operate it in 6 channel mode but only connect 5 i/ps and 5 sets of speakers you automatically get this 5x70w effect?
    I am going to use it to drive 4 rear surrounds and a front centre but do not want to bridge the centre channel as the speaker is rated at 6ohm probably based on a 4 ohm design. I'm also not keen on the distortion bridging introduces.
    Would I get 5x70w?
    Torq
