Rotel RA1592
Rajeev Kale
Hello friends
I am in the process of upgrading my existing system. I have Marantz PM 14 S1 Integrated Amplifier and PMC twenty 23 tower speakers.
I want to get Power amplifier which will allow to have subwoofer to my existing system.
The current integrated amp I will use as Pre amp , take pre out and connect to power amp which will have subwoofer out as well.
Please suggest best suitable power amplifier for me.
I will be using the same set up for my home theatre as well . I have Denon 7200 WA AV receiver for my home theatre set up.
I have SVS PB 1000 subwoofer which is connected to my Denon AVR.
I want to use the same subwoofer and PMC L & R set up for both Theatre and Music please advice suitable power amplifier .
regards
Rajeev
Report
D
Deleted member 39241
Hello.
You are using a Denon 7200 AVR for movies, with the Marantz PM14SI via power amp direct in, as a power amp for the front two speakers with the AVR, and as a standalone stereo amp for music.
But, your SVS PB1000 does not work when listening to music (to be expected).
I am not sure why you mention a power amp, or the Rotel RA1592?
Can you confirm that you want the subwoofer to work when listening to music via the Marantz, or is there something else you want to change with the system?
LG SP11RA Soundbar Review Coming Soon to AVForums
