Rotel RA-1212 comments (is it worth getting repaired?)
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by Chiggs, Feb 25, 2003.
  1. Chiggs
    Chiggs
    I've got a Rotel RA-1212 integrated stereo amp (can't find anything about it on the net) it's a bit of a beast (450watt RMS).
    It doesn't work when an RCD fuse is used in the supply which means that it leaks > 30mA to earth from live/neutral. It works at my house (conventional fuses) but not in halls (RCD trips).
    I would like to get it looked at, i know the amp works but has an earthing problem. Where can i take it, how long will it take, will it definately be fixed, and how much will i get charged for this?
    Any ideas/comments welcomed
    Chiggs
  2. petrolhead
    petrolhead
    Mar 29, 2002
    4,783
    87
    Newcastle
    +116
    Maybe worth putting this question on this part of the Forum - Hi Fi systems, separates and other music delivery systems and formats - which is below Speakers
