Rotel RA-1062 CD Partner
Discussion in 'Hi-Fi Stereo Systems & Separates' started by peterlowe, Apr 5, 2005.
  1. peterlowe
    peterlowe
    Hi everybody. I currently have the B&W 603 S3 with the Rotel RA-1062 amp and RCD-02 cd player. I am very keen to upgrade the CD player as is currently the 'weakest link' i feel. I am very serious about the RCD-1072 (obvious choice), but wondering if anyone has compared the RCD-02 with the RCD-1072 and the extent of improvement? Many thanks
    - Pete
  2. SKA.face
    SKA.face
    I think it's a well balanced system,I don't think the CD player is a weak link.I would keep it as it is,if you must change,I would try the 705 instead,maybe less bass,but more everything else.
  3. superpixel
    superpixel
    What in particular about the sound do you want to upgrade?
    The obvious upgrade to your system is to add a power amp (Rotel RB-1070 or 1080). But it all depends what you want to try and achieve.
  4. Harry T2
    Harry T2
    Jul 29, 2004
    482
    +10
    You could experiement with a 2nd hand DAC, as a much cheaper alternative
  5. peterlowe
    peterlowe
    I initially brought the Rotel RA-02, RCD-02 with the B&W DM602S3. Over the last year I have been upgrading components slowely, one-at-time and I noticed improvements all round with each advance. First the Amp to the RA-1062, followed by upgrade to the Kimber Silver Streak interconnect (superb cable btw!) and the B&W 603S3. I have to say the system sounds so much better now and so I am naturally expectant that I would notice an extra sheen of realism from matching up the Rotel 10 series amp with the 10 series Cd player. I was just curious as to whether anyone else had made this upgrade would say it was worthwhile or perhaps the difference is relatively negligible?
    Incidently, I heard one of the new B&W 800 series speakers today (£13k) hooked up to twin power amps (£8k each) and the cd/pre amp (£8.7k) with interconnects/cable that looked like something out of star trek! To be honest, they sounded as perfect as you could ever want....! (not that I can afford them, esp. at only 18 years of age!)
