Rotel 1075
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by riddler, Aug 8, 2001.
  1. riddler
    riddler
    Does anyone have one of these ?<br />I too missed the issue of hcc with it in <img src="frown.gif" border="0"> <br />Ive look throughout my hcc mag and cant find any info on ordering back issues.<br />Im considering using it to replace the onbaord amp in my sony 940.<br />Does the rotel have alot more headroom than the sony.<br />Im aware just compairing rms outputs doesnt account for a great deal.<br />Can anyone who has bought this power amp give us some idea of what it is like please <img src="smile.gif" border="0">
  2. Laingy
    Laingy
    I have the Rotal 1075 partnered with the tag av32r, and they sound great together, not as good as the tag power amp but that was an extra £2k, I managed to get the rotel ex demo for £500, and it still is an excellent partner for the av32r. It has plenty of power and works well on both 2 channel and 5 channel. For the price I cannot recommend it high enough.
  3. Lowrider
    Lowrider
    I did add a Rotel RB993 3x200 to my Onkyo receiver, for the front and center channels, and it improved the sound a lot more than I expected... drums are sharp, a lot more detail, even clapping, instead of a blur I can almost hear each person, the midrange is beautiful...
  4. JDC
    JDC
    Riddler - I use a 1075. It packs more of a punch that the Sony, and then some. There's no 12V trigger, but what it lack in functionality, i feel it makes up for with the massive power reserves, plus it's fast & articulate. As always, do try to audition your short list of kit side by side. I've not heard any negative comments about these 2 amps (1075 & 1095), and they're very good value.
    Good luck.
  5. riddler
    riddler
    The rotel rb 993 is FIRST on my list. But im still saving and has been discontinued so im lining up a reserve <img src="redface.gif" border="0"> )<br />mark
  6. Guest
    I've had a 1075 for months. I first used it with a Yamaha A592 as a pre-amp, then a Rotel RSP 976 processor, now with a Tag Mclaren AV32R. I think it is absolutely brilliant and do not regret not buying the 1095 or the Tag 100x5R. It does have a 12 volt trigger and I used this facility when I had the Rotel processor. Unfortunately, the RSP ran so hot it died so I bought the Tag. Can't use the 12 volt trigger with this combination though.
